Injector Electrical Connections
Old Nov 4, 2017 | 03:26 PM
RussCdn's Avatar
Default Injector Electrical Connections
Are Siemens Deka injectors available with the Multec II electrical connections?
Or do I have to cut in some wire pig tails to match the EV-1 or EV-6?
This is definitely a modified and cheap project so the plan would be to pull an entire wiring harness from a donor vehicle and so far all the injector connections I have found on the stock engines in the yard have been Multec II.
Am I going to eventually find stock wiring harnesses in a truck/van that is EV-1?
Old Nov 5, 2017 | 09:31 AM
pantera_efi's Avatar
Default DEKA Injectors
Hi Russ, Deka 1 - 4 use EV-1, the Deka 5 - 8 use EV-14 connectors.
I have adapters for either style.
Lance
