Fuel/evap canister issue
Old Nov 21, 2017 | 01:07 PM
FU_I_AM_UltraZ's Avatar
Veteran: Marine Corps
Default Fuel/evap canister issue
Ok, i thought pump was breaking up and throwing small debris into gas I took sample from Schrader valve on rail. Don't think it was the issue. I replaced the 3in of hose off the canister at time of new pump assembly. Can bad canister throw charcoal into gas and clog injectors? Since all fuel lines are plastic or metal? I took old pump out and dumped gas out from inside pump and had small sand grain size debris i got from Schrader valve sample. Still getting that micro size debris after new pump so only thing i can think is the evap canister throwing small charcoal pieces into fuel. But how? Or did i get crap gas that had this debris in it and I'm still not rid of it?
Also, since new oe crap oversea made pump assembly, I've noticed an idle issue i can't seem to put my finger on. Idles tad high here n there, i just know from hearing it as its not acting normal.
HELP PLEASE.
Thx in advance
Old Nov 21, 2017 | 01:11 PM
There should be NO way for the canister to put debris into the fuel. In fact there should be NO way for liquid gas to get into the canister at all. If it's plumbed correctly, that is.
Old Nov 21, 2017 | 01:28 PM
Oe complete on all that part
Old Nov 21, 2017 | 01:32 PM
Just thought, fill tube is rubber... Really over looked that part... Hope that's the cause
Old Nov 21, 2017 | 01:51 PM
01ssreda4's Avatar
Not true. It happens when you overfill your tank. Charcoal gets gas soaked, prevents proper venting, and you get the gas spitting back out at you at the pump. Best thing is just removed the damn thing. I have 3 vehicles with it gone and ZERO gas fumes or any other issues.
Old Nov 21, 2017 | 02:02 PM
OK, my education is furthered! Thank you!
Old Nov 21, 2017 | 02:17 PM
01ssreda4's Avatar
I have one vehicle with one clogged. She refuses to fill the thing so i get to take it to the gas pump weekly. Grrrrr.
Old Nov 21, 2017 | 02:21 PM
Life's little hassles....
Old Nov 21, 2017 | 06:36 PM
Not from over filling for sure bc i normally fill half tank at pump. Most at 3/4
Old Nov 21, 2017 | 07:59 PM
01ssreda4's Avatar
Idle issues I would lean towards basic sensors like iac tps map and 02s
Old Dec 13, 2017 | 08:25 PM
00pooterSS's Avatar
A lot of times when I hear this problem at the shop I find a vent valve stuck closed or clogged vent valve filter. I haven't seen a clogged charcoal canister yet (in 20 years) and I do this every day, but on all makes and models, never really see F bodies, however my F body was a pain to fill with fuel but I never felt like messing with it so I didn't.
Vent valve is the evap valve at the tank and is a normally open valve. If it isn't open the tank won't vent and allow the air to come out and fuel to come in.
Old Dec 14, 2017 | 08:18 AM
01ssreda4's Avatar
That may be it as well. Need to blow some air through the line or something.
Old Dec 14, 2017 | 10:41 AM
00pooterSS's Avatar
With the key off the valve should be open man, with the key on it's usually closed if that helps ya. If you have a scanner that can command it on and off that would really help
