Holley sniper EFI
trying to follow this but obviously im new to efi etc.....
Ive got a similar set up in a 67 Chevelle. 06 GM LQ4 with 242 heads
and a Texas Speed cam 236/242 .600/.600 110+2 LSA.
Trying to decide on carb type efi with self learn ecu or go with the fabricated intake type....Currently was looking at Holley Sniper efi (carb style) and FI Techs Mean Street 800 as well....
The way I see it you are spending most of the money to get an EFI system you might as well get something you can learn and will grow with you while getting all of the advantages. You can still do a throttle body with 8 port injectors. The smaller plenum will make it easier to get a stable idle. They can still sell you the self learn type kit with small screen to start out and later you can connect a laptop to the HP and have full system. The 8 injectors means you can start with this motor, then add nitrous, then build a new stroker, and then upgrade the nitrous up to 1000HP and never by a new part for the EFI if you start with 66lb injectors. You might not want that much, so maybe some 42lb or 48lb for a 408 with a 200 shot later.
