Convert from '98 metal tank to '99+ plastic tank?
Tell us how that works out...
Cool then that should work the way I have it set. I set it to E when I have about 2 gallons to go.
I talked to someone at Battery Tender and was told to send it in an email so that they could get it to the right people. Waiting to here back. Also, had a customer come in with a great deal on a lithium, but won't believe it until we get to test out the claims. The money is just to low to accept before seeing it.
One way to save quite a bit of weight is to go to a light weight windshield. I just had mine replaced and there is at least 30lbs difference. I had to readjust my headlights afterwards because the frt end went up that much. I was really surprised, the replacement is easily 1/4 inch thinner but it meets the DOT spec?????? I hope. Dam thing is made in china too. Without a doubt with me alone in the car I can feel the difference, I do like it. Because it so thin it is very easy to see through too.
Well, this does look awesome. Might have to check that out one day. Here is what I found.
For those of you looking to shave weight from your race car, Optic Armor guarantees that these windows can reduce as much as 75% of the weight that you would normally have with factory glass. Dunham told us, “On a ’93-02 Camaro/Firebird, you’ll drop 47 lbs. from the factory front and rear glass by switching to Optic Armor.”
Going a step further, Optic Armor claims they are an amazing two-hundred-fifty times stronger than the OEM glass. A claim that Dunham makes on the companies behalf due to the incredible amount of man hours spent researching and developing each and every Lexan window that they produce.
From- http://www.lsxmag.com/tech-stories/p...armor-windows/
If going on a street vehicle, don't expect it to be legal. Lexan windshields are not street legal.
While the windshields are not DOT certified, the side and rear windows are, according to Dunham. For this reason, it’s not recommended that you replace your factory windshield on a street-driven car, especially one that sees regular street use. Even though there are some great benefits and qualities to Optic Armor’s replacement windshields, Uncle Sam is very strict about what can and can’t be used on the street. Again, this goes back to the windshield being a structural part of a unibody vehicle and government regulations play a part into that decision.
Looks like the hydramat sizes are generic. Which are compatible with our tanks and fuel pumps?
https://www.holley.com/products/fuel...mat/hydramats/
For those interested in optic armor, here ya go.
https://ls1tech.com/forums/drag-raci...l-f-r-how.html
#33
I have no doubt the newer chinese glass saves weight, Im not arguing that point, it is thinner by several peoples account. But it wasnt 30 pounds saving and it didnt make your car sit higher.
#34
So I've already got a Racetronix 255LPH kit + hotwire system. How much of that system is compatible with the '99+ tank conversion? I'm thinking if I can find the right size hydramat, that even though there's more cost that it's less potential frustration down the road.
#35
Racetronix kit purchased in 2004 would have to be upgraded. The bucket is different as well in 98's compared to the 99-2002.
WS6 told me last week that they are working on an upgraded kit for the 98. So the new upgraded 98 kit combined with the c5 fuel/filter pressure modification kit means I can run a 340 and still not have to upgrade my fuel lines and be good to 750 rwhp. The combined kits cost far less than a dual pump kit and no downtime sending in your fuel module.
But best to check with them first for specifics and timeline. Sounded as if it is in the works now.
IMO, there are other less costly weighs to reduce 20 lbs of weight than a plastic tank. I think a set of skinnies in the front gets you there, and/or a set of lites in the rear.
#36
I would contact WS6store (a sponsor) for similarities if any. For example, they told me that the bulkhead has been upgraded to handle more amps because the larger pumps such as 340 or 450 draw more amps. My 98
#37
Sorry - didn't notice until your last post that you are building the car for HPDE. Understand completely why fuel starvation is a concern of yours.
However, might review this post concerning the plastic tank being lighter. OP there say weight is the same.
https://ls1tech.com/forums/fueling-i...-write-up.html
#38
#39
