99 c5 fuel filter/regulator on 1998 camaro
I recently bought the kit from ws6store for the c5 fuel filter/regulator install. I got underneath the car and started to mock it up to see where i will need to cut the hard lines and I cannot figure out how to get the new filter even come close to fitting. Obvious i know the hard lines will need to be trimmed but just based on the t that was removed i dont see any physical space to mount the filter with all the adapters let along getting into the angles of the hard lines. I was wanting to see if anyone has done the conversion if they can post up some pics of how the fuel filter is mocked up. I have some pics of what i am talking about. thanks!
I was able to get the system in. I have some pics of what i did. I did not use the supplied hardline and i was able to reuse the stock hardline elbow. seems to be all good. the mounting was a little complex but it is tucked nice in board on the rail. The also installed a ractronix fuel pump and hotwire kit and i am showing 70 psi at the rail with a rail mounted fuel gauge.
I hope the pics help!
The following users liked this post:
Crf450r420 (07-29-2019)
This regulator upgrade is a nice piece. Just make sure to take out stock in-tank regulator. Your upgraded fuel pump will thank you. Don't be surprised if upon start-up you hear a "whushing" noise due to increased fuel flow. It's apparent, especially if you have an upgraded fuel pump. Once you start moving, your exhaust and other noises will drown it out.
steve000 (10-25-2023)
