Fuel rail/system setup questions
Old Mar 27, 2018 | 10:27 AM
blk99camaro's Avatar
Question Fuel rail/system setup questions
So here is what I have:
2-450's/billet hat (chrs1313) with -8an feed AND return.
Fragola -8an PTFE lines/fittings
Fuel rails- Open to suggestions, would like something with -8an fittings/full flow
Magnafuel MP-9950 Boost ref FPR
Deka 80#
I have the line for the feed running to a y-block and then feed to the back of each rail.
The return is the other thing I haven't figured out:
Should I run the rail returns to a Y and then one single line to the FPR, OR since the FPR has 2 -8an inlet ports should I just run the return line from each rail independently to the ports on the regulator?
Thanks!
Jon
Old Mar 29, 2018 | 06:35 AM
No one?
Old Mar 30, 2018 | 08:21 AM
01ssreda4's Avatar
I did that and fed both rails back into the regulator as seen here. Return is on the bottom.
Old Mar 30, 2018 | 08:24 AM
01ssreda4's Avatar
Here's another one i setup the same way.
