High or low impedance?
Old Apr 29, 2018 | 11:03 AM
92gearhead's Avatar
Default High or low impedance?
Just starting into the turbo gig and have a bunch of questions but I知 just gonna tackle one at a time. I知 looking to buy some 60 or 80lb Deka injectors and I知 not sure which impedance I need? What痴 factory?
Old Apr 29, 2018 | 03:21 PM
pantera_efi's Avatar
Default Injector Current Requirement
Hi 92, what EMS will you use in your project ?
Lance
Old Apr 30, 2018 | 05:51 PM
92gearhead's Avatar
I値l be using the 411
Old May 1, 2018 | 07:25 AM
JoeNova's Avatar
Restricted User
High.
Old May 1, 2018 | 10:24 AM
Default 411 = 14 Ohm
Hi 92, the OEM GM "411" REQUIRES a 14 Ohm fuel injector as the PCM is fitted with a eight channel driver IC WITH Fault reporting required for OBD rules.
A TWO OHM fuel injector will not be allowed to operate due to the difference in current flow.
MOST, ALL, modern fuel injectors have a better designed magnetic circuit requiring LOW current.
I would like to supply your fuel injectors, Denso 650cc OR 850cc ? (flow matched)
What is your length requirement ?
Lance
Old May 1, 2018 | 12:29 PM
92gearhead's Avatar
Ty, they are 60mm I believe, or whatever stock length ls1 injectors are. Do you provide all the injector data for tuning hp tuners?
Old May 1, 2018 | 12:36 PM
92gearhead's Avatar
And I guess the equivalency of 80lb so I have a little room to grow I do need to be more Familiar with the cc
Old May 2, 2018 | 01:33 AM
Crf450r420's Avatar
CC and divide by 10.5 for pounds.
Old May 3, 2018 | 09:21 AM
Default Fuel Injector EV-14 Long 80.lbs
Hi 92, OK the EV-14 Long.
The EV-14 term is for the injector connector specification AC (American Car) or the Older EV-1 Bosch style choice is next ?
Post a picture of the injector electrical connector if you are not sure.
What fuel pressure will you operate at in the fuel rail ?
The fuel injectors I provide are Flow Matched (set of eight) along with a Dead Time Specification needed for some EMS calibrations.
Lance
