Fuel pump keeps shutting off!
Old May 14, 2018 | 09:09 AM
kdavis347's Avatar
Default Fuel pump keeps shutting off!
I have a 1998 Camaro Z28 5.7L and my wire harness from fuel pump to the body plug is burnt and keeps losing connection causing fuel pump to shut off. If you push up on the plug going to body fuel pump will start working again. I have a new wire harness from a 2002 Camaro Z28 5.7L. Will it work on my 98? Attached is the new wire harness.
