Quick Fuel Pump install question...
Old May 24, 2018 | 07:30 PM
dan.b's Avatar
Default Quick Fuel Pump install question...
I know another racetronix thread.. trust me I searched for over an hour..
Installing racetronix kit..primed pump assembly before reinstall and it’s dripping from the bottom nylon sock. Normal? Had trouble getting the snap ring on, maybe I bent/cracked it?
Thanks
Old May 24, 2018 | 08:39 PM
dan.b's Avatar
Update
I think I may have found the issue, if someone can help confirm.
The black venturi siphon valve (I believe it’s called - pictured right) was dislodged from its hole on bottom of bucket (pictured left) while tapping on the nylon sock. It looks like it was glued in place from factory. Anyone know if this is not supposed to be detached?
