03 up Cobra injectors fit ??
Old Jul 7, 2004 | 10:45 AM
JoeDirt's Avatar
Default 03 up Cobra injectors fit ??
Is there a difference ?? What year ligtning injectors fit ??
Old Jul 7, 2004 | 10:47 AM
Nasty N8's Avatar
Yes they are standard size injectors. 99 up Lightnings had the 42#es too.
Nate
Old Jul 7, 2004 | 11:20 AM
JoeDirt's Avatar
Thanks thats what I thought , I was told the new ones had a difference something to do with gen II vs gen III
This is what I wanted to hear
Old Jul 7, 2004 | 04:01 PM
slow's Avatar
unfortunately they are not standard Bosch style plugs.
mechanically they will work, but the connectors are not the same.
Ryan
Old Jul 7, 2004 | 05:48 PM
JoeDirt's Avatar
What do you have to do to make them work ?? I can get a set of 03 cobra 39 lb per hour injectors for 175 shipped is it worth it ??
Old Jul 9, 2004 | 02:59 PM
J.R.'s Avatar
I guess you could make some connectors to make them work 175 is cheap !
Old Jul 12, 2004 | 12:24 AM
JoeDirt's Avatar
Does anybody know where I can buy the pig tail adaptors to convert type III stick style injectors to type II ls1 and older mustang style ??
Old Jul 12, 2004 | 12:46 AM
JoeDirt's Avatar
Old Jul 12, 2004 | 12:58 AM
chpmnsws6's Avatar
my injectors?
Old Jul 12, 2004 | 01:06 AM
JoeDirt's Avatar
No I dont think so ?? I gave up trying to get a set of 42.5's at a decent price is like pulling teeth
Old Jul 16, 2004 | 03:37 PM
HellOnWeelz's Avatar
I've looked into getting the pigtails, and the only place I've found them is from Ford motorsport but they are $25 ea, and they are not adapters just plugs. Needless to say they can kiss my ***. I am going to go to the junk yard and pull a late model mustang wiring harness or something like that and splice in the Ford style plugs. The plug itself is used on all different applications...injector, brake sensor, speakers, parking brake, PS pressure so I don't think it will be hard to find enough plugs to work. If I could just find out who makes those plugs for Ford, I'd be in business.
Depending on what your time is worth it will probably still be worth it if you can get a set for cheap. Just my .02.
Old Jul 17, 2004 | 09:10 AM
JoeDirt's Avatar
Yeah I have one set here almost brand new so its worth it imo , thanks for your help
Old Dec 14, 2004 | 09:31 PM
obrien24's Avatar
as do I. I just bought some 39# once for 100. I need to figure out how to make it work.
Old Dec 15, 2004 | 09:40 AM
I ended up just going to the junkyard and cutting plugs off of two, 4 cyl injected engines. I think they were 2.4l or something like that. Just take an injector with you and match it up. The junk yard guys are pretty good about you taking them if the engines are cores only. Only cost me $15. Remember that the injectors are polarity specific so keep track of which wire is positive on your wiring harness. They will be marked on the plugs.
Old Dec 19, 2004 | 11:53 AM
injectorman's Avatar
I have the harnesses either way. Pigtail or plug in...
Old Dec 19, 2004 | 12:19 PM
obrien24's Avatar
you have an adapter that will go from ls1 harness to the cobra injectors
