LS1 fuel line size
5/16 -6AN
3/4 -8AN
Using a 99-02 Camaro Fuel pump (combining the supply and return of the pump into a Y and running directly to the fuel rails
tried searching but cant find answer.
What is the stock line size for LS1 ?
Going in 1980 C3 corvette. It had 2 rails, one 3/8 and one 5/16. But im running lines on other side so i need to run a new line. Will use Summit Racing® Stainless Steel Hose SUM-230620. Not running E85 or ethanol.
I have a bunch of 5/16 6AN fittings so i hope i can use them and the -6AN hose i have
