midnight teaser pics
Its not just overkill, its taxing on the entire charging system for no reason. Plus the data is still new on it for longevity without a controller etc.
The 450 and 490 options will handle most anything you throw at them to over 900rwhp in quite a few cases on E. The builds that are having issues are definitely not running out of actual pump though. Its usually due to insufficient fuel system design or charging system/wiring issues.
Putting the biggest pump you can in a setup isnt always a good idea. You need the proper pump for your setup. Until the actual longevity of the 525 pump is known, we will likely be holding off on making them.
http://www.ws6project.com/user_stor/...&filter_id=180
Will the 495 venturi pump be available separate?
Same pn from ti automotive/walbro to racetronix.
Too many people keep contacting us asking for it and thinking the 490 wont be enough. Do. Your. Research. Racetronix offers a 535 pump but we are not going to use that on the buckets for a few reasons.
Also this pump puts out 106g/hr or roughly 400lph at 60psi at 13.5V and 20A.
We are the only ones offering this with venturi also which helps keep the pump fed and cool.
I cannot stress enough to do your homework. And if you cannot or do not know how, then ask.
As the post says it was a midnight thing, so most of that was done while i was assembling modules and doing a bit of research.
We decided to skip the 450 altogether and go straight to the 490. Racetronix did change their rating i think from the 495 to 490 so thats the option we have, which does about 401lph at 60psi as stated earlier.
The 535 they have that so may are now trying to use doesnt have a check valve and doesnt have alot of info published.
I didnt realize the total difference until a few more hours of research this week. It is ok to update info isnt it?
Build the fuel system for you power goals. Overbuilding is a waste of money there.
Most of the issues related with people running out of pump before the rating of the pump actually is is normally due to insufficient voltage or current to the pump, improperly plumbed system, or an overly rich afr. OR using cheap pumps or questionable pumps.
There are so many reason to keep it as simple as you can for as long as you can. A 5.3l takes quite a bit of boost to overpower a 340 pump and even more to push a 4xx pump past its limits.
