midnight teaser pics
Old Jul 27, 2019 | 12:47 AM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
Default midnight teaser pics
Pic 1
Pic 2
More info later tomorrow (today)
Old Jul 28, 2019 | 11:38 AM
1FastBrick's Avatar
New hi flow pump your testing out?
Old Jul 30, 2019 | 07:37 PM
No Juice's Avatar
Ummmm…...….so?
Old Jul 31, 2019 | 09:49 AM
psicko's Avatar
Looks like a Racetronix 340 kit.
Old Aug 1, 2019 | 12:16 PM
First pic is a new 340lph racetronix pump WITH venturi so thats a game changer.
And we are now offering 255lph pump kits again for 99-02 AND 340lph pump kits also fully assembled and ready to go.
We should have a few done soon and ready to go.
We will also have a 450/490/525 kit available for drop in with venturi and likely some dual 255/340/450 kits with single venturi off them also to keep the pump modules filled with the larger 19mm/22mm inlets pumps also!!
Big things happening
Old Aug 1, 2019 | 12:40 PM
stealth355tpi's Avatar
Will the vette regulator work with the 450 kits? Been looking at the 340/regulator combo for awhile now, curious how much FI power they'll support.
Old Aug 1, 2019 | 01:03 PM
So far it has worked well for a few customers.
Old Aug 1, 2019 | 03:04 PM
sjsingle1's Avatar
is that in the new style bucket or the old ? or works in either ?
Old Aug 1, 2019 | 03:12 PM
These are brand new modules.
They will work in either style but for gods sake stop drilling holes in buckets lol.
This is also a more in depth look at the c5 filter reg kit install to show what it looks like to remove the regulator and housing and replace with tube etc.
Old Aug 6, 2019 | 11:57 AM
chevykev's Avatar
Is this a complete drop in for a nnbs truck? I have a 450 already to go but rather not drill my bucket
Old Aug 6, 2019 | 03:26 PM
I would need pictures of the module to check.. they change so many things on the trucks and there are 10 diff types of modules.
If sending pictures email to rpmspeedtech@gmail.com
Here is another picture as to why the stock regulator is insufficient on larger pumps. The return fuel is pushed through the steel tube and down the tube to the bottom of the module. Those holes and that tube can only return so much fuel before the regulator is overpowered pressure goes up and usually the housing breaks or deforms. Ill have a full post on this soon
Old Aug 7, 2019 | 02:12 AM
klinznilk's Avatar
Are you removing the return metal line on these eventually? I am interested however I have regulator at rails and would not want that.
Old Aug 7, 2019 | 01:34 PM
psicko's Avatar
That metal rod has to stay, but you bypass it by removing the regulator housing. That white plastic line next to it is the new return.
Old Aug 7, 2019 | 02:37 PM
klinznilk's Avatar
I bypassed already on my current one. It was a pain in the **** to get off.dremel and all. I should clarified.
Old Aug 7, 2019 | 04:57 PM
Some people cut them but i do not recommend that. It is still needed for support of the module.
They dont function at all once the regulator housing is removed.
Old Aug 19, 2019 | 05:48 PM
mike135531bubba's Avatar
Any plans to offer complete kits, such as dual 255s with fuel rails, fuel lines, fittings, etc.?
Old Aug 20, 2019 | 01:25 AM
We pair the duals with the racetronix fuel line kit quite often.
I may start making some dual pump kits to keep on the shelf...maybe 1 of each. But only for 99-02 as the 98 modules are still pretty high priced which is ridiculous. But we can do new 98 modules also. And may offer some truck module options.
Old Sep 5, 2019 | 12:32 PM
psicko's Avatar
When are you guys planning on having these available?
Old Sep 5, 2019 | 12:39 PM
WS6store.com's Avatar
LS1TECH.com Sponsor
We currently have 1 x 99-02 Racetronix 340 Module kit in stock, and 1 of the 255 kits in stock, ready to ship.
Old Sep 5, 2019 | 12:58 PM
psicko's Avatar
I've already got the 340 kit from you guys. Just curious about the 525 venturi kit. I am pretty sure I'll want to upgrade in the near future.
