2001 WS6. No spark out of Ideas!!
Old Sep 6, 2019 | 04:30 PM
mattg1's Avatar
Default 2001 WS6. No spark out of Ideas!!
Hey guys. I have a 2001 Trans Am. Stock 50,000 mile car. Was driving fine yesterday and suddenly started spitting and sputtering and then died. Pulled codes and there were 12 codes ( I know right ). Codes were for all 8 coils and knock sensor codes. Which were just replaced with OEM units and I replaced the harness for them also. Car would at least turn over and start for a split second but now will not run at all. Car has fuel but no spark. There is power to the coils. Any help would be greatly appreciated!
Old Sep 6, 2019 | 05:22 PM
Check all grounds, especially those on the back of the heads. You have power to the coils, but without a good ground it has nowhere to go.
Old Sep 6, 2019 | 05:27 PM
mattg1's Avatar
Wiggled ground on drivers side head and it did start and burble for a second and died. So I ran a cable from the negative terminal to the ground on the back of the head and it didn’t make a difference
Old Sep 6, 2019 | 08:18 PM
There are also grounds on the passenger side head.
Old Sep 6, 2019 | 08:33 PM
mattg1's Avatar
What all grounds there?
Old Sep 6, 2019 | 08:37 PM
Injectors, coils....
Old Sep 8, 2019 | 11:34 AM
mattg1's Avatar
There is not a ground on the passenger head of my car. Just the drivers side and it is tight and clean of debris
Old Sep 8, 2019 | 11:43 AM
01CamaroSSTx's Avatar
No ground on the passenger side, driver side only. Another ground is located on the engine block next to the starter and the other ground is connected to the frame on the driver side and is a copper strap that comes of the engine harness near the alternator. Have you checked your fuses to see if any are blown?
Old Sep 8, 2019 | 12:09 PM
Did you do something wrong with your installation of the coils and harness? Are you sure your have it wired correctly? Call me a dinosaur but what was wrong with the age old technology? It was simple, you gave it fuel, air and spark and it worked.
Old Sep 8, 2019 | 05:21 PM
mattg1's Avatar
Gotcha. I will check those grounds next. And I checked all fuses and relays and they all appear to be good. I swapped some around with each other and with a different car and no luck. Also left battery disconnected for a day hoping the ECU would reset but that didn’t help either
Old Sep 8, 2019 | 05:52 PM
Serrato's Avatar
Make sure the coil harness isn't backwards as in 1 and 7 aren't flipped over. Same for both banks
Old Sep 8, 2019 | 06:33 PM
mattg1's Avatar
All that stuff should be fine. The engine is untouched
Old Sep 17, 2019 | 06:53 PM
mattg1's Avatar
So update. Replaced crank sensor with OEM unit today and still no start. All the wires were in good shape also. I am at a loss
Old Sep 17, 2019 | 07:19 PM
Its either something is not connected, something burned out and lost its connection or something is not grounded. Post up some pictures of the engine and the harness connections so we can see if anything jumps out. So hard to diagnose these types of issues without being at the car to investigate.
Old Sep 17, 2019 | 08:04 PM
mattg1's Avatar
Grounds are all tight. Harness connections are all perfect and have never been removed. I’ve owned the car since it was new.
Old Sep 17, 2019 | 08:29 PM
Codes were for all 8 coils and knock sensor codes. "Which were just replaced with OEM units and I replaced the harness for them also". Car would at least turn over and start for a split second but now will not run at all.
Who did the replacing? Was it just the knock sensors and harness that was replaced? To replace them requires disconnections and re-connections. Hard to tell what exactly the issue is when your not at the car and know what all has gone on.
Old Sep 18, 2019 | 04:47 AM
mattg1's Avatar
They were replaced at a G.M. dealership last summer. Haven’t had any issues until now when the codes popped up again
