416 stroker fuel lines
Old Sep 16, 2019 | 11:27 AM
Loki67's Avatar
Default 416 stroker fuel lines
What size fuel line are u guys running? I have a boys welding fuel cell. Seems like ppl run a #8 or#10 to the regulator and the #6 from the reg to the rails. Will the 6 be big enough for the stroker. The cam is not too big and runnin factory ls3 intake for now
Old Sep 16, 2019 | 02:42 PM
Loki67's Avatar
And also, will the factory ls3 injectors work or should I look into upgrading?
Old Sep 16, 2019 | 03:52 PM
Injectors are sized to power output. How much HP are you running?
Old Sep 16, 2019 | 04:51 PM
joyridin''s Avatar
8 to the rails and 6 return. My regulator is mounted on the rail.
Old Sep 16, 2019 | 07:47 PM
Loki67's Avatar
For now I believe I will be around 600 hp
