removing the fuel rail...
slip the tool over the fuel line,then slide it "into" the connector..its hard to explain,the the tool will slide into the fitting almost a 1/4 inch and this will relaese the clips that are holdiing the line on. just make sure you push the tool all the way in or it wont release. on mine the "lip" is almost completely inside the fitting therefore the handle of the tool is agains the fitting,give it a tug and it will come off.
