Help me choose injectors
Old Jan 28, 2020 | 05:57 PM
Fah Cue's Avatar
Default Help me choose injectors
What's up guys!
She's coming along and getting parts together. All I need are injectors and pushrods.
Here's my combo,
It's a stock inch with CNC'd 243s from livernois
Its got an MS4 cam a fast 102/102.
I'm liking the Siemens deka 60s and the green giant 42s. Both are rated at 39psi
Here's my reasoning.
With the 60s I'll have some room to grow. At the power I'll be at, I'm figuring 35 percent duty cycle. Problem I've read is that the idle quality will suffer because the injector opening time at idle is too long and it'll run really rich and shitty.
The green Giants are 42s and should put me around 50. I'll still have some room to grow, but from what I've read about the idle quality, these would be better.
So my questions are suppose I run the 60s and try to tune them to idle decent and have plenty of fuel for future
Or run the 42s, have a really good idle quality, have enough for for now, but outgrow them.
Thanks guys!
Old Jan 28, 2020 | 11:18 PM
onebadbowtie86's Avatar
Are you staying 93 octane or e 85? if staying 93 just get some stock ls3/7's. They are cheap enough that if you change directions in the future you wont be out a bunch of money and should be able to re sell them easy enough.
Old Jan 28, 2020 | 11:27 PM
98CayenneT/A's Avatar
Bosch GTP injectors.
$100 for 8
That's what I run
Old Jan 28, 2020 | 11:38 PM
$100 for 8
That's what I run
Three of my friends cars are running these, also a great option.
Old Jan 29, 2020 | 08:22 AM
Fah Cue's Avatar
I was tossing the idea around early on about goin with the short 3/7, injectors, but I read about guys having issues with the spacers, whether to put the spacers above the injectors or below, which spacers are better. I just couldn't get there.
I got a new in box oem ls2 rail for 77 shipped, so I started looking real hard at ls2 ev14s, but they are more then I need to spend.
Decided to go ls1 style because they're cheaper, but just as good, a plethora of data is available, and the rail situation is easily handled
I'm staying pump gas. May throw some 110 in there once in a while one I get a wideband.
$100 for 8
That's what I run
What's your duty cycle? Idle quality?
iirc your combo is pretty similar to what mine will be.
Do you have an hp tune file you could share?
Old Jan 29, 2020 | 08:32 AM
I do not do not do my own tuning but I have zero idling issues and my duty cycle is somewhere around 65-70% iirc
Old Jan 29, 2020 | 11:04 AM
I run ls3/7 injectors in my car with a fast 102. Fast spacers under the injector, supposedly the spacer is better on top but seems to work just fine to me? ls3/7 is easily found also for the ls1/411 ecm. The gtp’s do work well though, the only thing I question about them is how closely they are flow wise. They are ugly but they do work.
Old Jan 29, 2020 | 01:11 PM
LS_ELKO41's Avatar
$100 for 8
That's what I run
Where'd you get yours? I bought some used ones on the marketplace here and am not sure if I should send them out to get serviced before putting them on to get tuned. That would be like $160 minimum on top fo the $75 I paid here which would put me at the price of new ones basically or at least flow matched and verified.
Old Jan 29, 2020 | 03:15 PM
I got mine off ebay from a shop in California.
They said they were cleaned and flowed but I did not get a sheet with them.
The only thing I did was put some air pressure to them to make sure none were stuck open.
Old Jan 29, 2020 | 03:31 PM
LS_ELKO41's Avatar
I just saw some out of Denver for $90 called Injectordyne. Says they are cleaned and flow matched for $90 and are Bosch GTP remans. I might go that route instead of gambling on the ones I have now.
Old Feb 2, 2020 | 09:38 PM
Fah Cue's Avatar
Just a question, but are you sd or MAF? I'm thinking about smacking it with a small shot so this might be a little small.
That's what I heard. The spray pattern gets bent or some term when the spacer is on the bottom.
I ended up going with the green Giants. I got a set for 100 bucks shipped.
