Factory flex fuel setup
Old Apr 30, 2020 | 01:52 PM
Wild bill 4883's Avatar
Default Factory flex fuel setup
I have an L96 that was setup for flex fuel, can this be made to work in the same capacity as the factory setup in a swap? Running PSI conversion w/E38, I’m looking to be able to run gas or E85 or a mixture of both just like factory where a sensor and the computer makes adjustments To compensate for what it’s burning. I used all other components in the fuel system to be compatible.
Old Apr 30, 2020 | 02:08 PM
68Formula's Avatar
I believe all the GENIV setups used the "virtual sensor" which essentially an algorithm that estimates alcohol content based on fuel trims after the PCM detects a change of 3 gallons or more in the tank (indicating a refill). There is no real sensor. But I I think it's also possible to convert to a true sensor setup.
Old Apr 30, 2020 | 04:23 PM
The fuel level in this swap would be stand alone, I know there is a sensor that can be added in the fuel line. What I’m not sure about is if the E38 I have has the capability or if the capability is disabled when it was reflashed. I was hoping someone is running both fuels with success.
