Kinked your racetronix venturi tube ? fix inside !
The following users liked this post:
Forcefed2002 (04-30-2020)
I remember we had this same problem and we would have fuel starvation after driving for a while.
It was around 6 months later the issue arrised.
Whats messed up was we asked on here about our issue.
Racetronix answered saying this has been covered in our support forum.... f-that just tell me wtf the problem is.
Racetronix never answered or helped in this forum on the issue.
Then trying to join was a pain in the rear which didn’t happen as it wouldn’t let me get passed the birthdate info.
A guy posted a link to a guy who had a similar issue.
We dropped the tank and it was kinked when we took it out or you could see the kink that was there.
i dont know what is worse.....a brand new tube that kinks when you install it.....or the old one that was so shot it crumbles as you remove it
moral of the story.....if you have NEVER changed your fuel pump and/or hoses......you are on borrowed time.....you may find yourself chasing problems you cant find fixes for cause you will never suspect leaky/shot hoses
and using the tube in the racetronix kit may be frustrating too
it crumbled even more after the pic
LilJayV10 (05-02-2020)
Problem started with low FP at WOT.
Put in a Racetronix pump in but problem was the regulator. After replacing regulator FP at WOT was fixed but now I had a starvation problem when tank was low. Turned out the venturi hose in their kit kept popping off the pump. Replaced venturi hose with the part number supplied by OP. Now everything works as it should.
