Retern line needs a check valve?
I just thought of something. You need a normally closed(open when powered) solenoid valve in the return. Might work...
Just a thought anyway
Maybe, just maybe, that's why the "prime cycle" is written into the ecm?
I don't think the "picky" description covers it............
Looks to me as tho you just like to hear yourself talk.
My previous posts assumed a positive seal at the fpr which obviously does not exist.
In order to get an instant start every time you hit the key the system pressure would have to be maintained while shut down. Even stock cars do not do this. To minimize cranking you have to power up, wait for the system to pressurize, then crank.
edit. You know, I wasn’t gonna say anything else but the more I think about your low key jackassery, I decided I might as well say something.
1) if my wife or someone else gets in the car and cranks it normally (no one knows to let it prime because that’s not normal on any other car) and it turns over and over like that....they are gonna think it’s a piece of **** that don’t wanna start. I don’t like that. Am I entitled to not like something about my own car?
2) I created this thread because this is the first time I ever had to create a return system. I fabricated the fuel pump bucket from scratch and modded what I needed to, to get this to work. I wasn’t sure if this was supposed to be like this or not. My 3rd gen camaro has a return system and I don’t remember it ever being like this. It always fired right up without priming.
so I’m not sure how you think I just wanna hear myself talk. Game tech gave me a great idea and that’s what the forum is for, right? To learn, help and in your case be a jackass I guess. Lol.
i need to see if there’s a regulator with some sort of valve. Would only make sense.
https://www.discovervalve.com/mm5/me...ct_Code=101137
its stainless steel, 8-10psi crack open pressure and it has a viton ball so it should seal well and keep fuel in the return side. Hmmmm. I think this looks a lot better than the jegs check valve I bought.
I'm not new to E85 or non stock fuel systems...I've been daily driving heavily modded SRT-4s with corn since around 2009. Those fuel systems are nowhere near this capacity, but they are designed essentially the same with the FPR right after the rail with pressure dropping slowly to zero after shut down, not dropping straight to zero in a couple seconds. Anyway, my srt-4 cranks right up even after sitting for a week or two.
#racecarlife
