Retern line needs a check valve?
Anyone else use a check valve? I already ordered a vibrant brand one.
I canceled the vibrant check valve. I had a brain fart and realized that the only thing it will do for me is prevent a siphon effect when I disconnect the return line. It won’t help hold fuel in my lines the way I need it to. So.....
I realized I need a check valve that has a cracking pressure. Maybe 5-10psi so it’ll keep the lines full of fuel but won’t necessarily be under pressure. Soon at I hit the key, the pressure should come up immediately. Yea, I’m being picky but I want it how I want it. Jegs has a valve like I need but they are out of stock. Ugh.
I got a check valve that advertises 5psi open pressure. So if it just keeps fuel in the line, the starts will be faster. I haven’t installed it yet so I’m not sure it’ll work. Im not happy with the sealing of it and the quality of it. The spring pressure sucks and it doesn’t seem like it would hold any fuel in the line.
If I turn the key in, wait a second or so and then turn the key, it fires right up. If I just turn the key quickly, like I’ve done my whole 27+ years of driving....then cranking time is much longer. And I don’t like that. It’s like 2 seconds of cranking which sounds like I’m cranking a car in the cold on e85. I just don’t like it. So I’ll figure it out. It runs for now and gets the amount of fuel it needs so I’ll live with it for now. Till I have more time to fool with it.
my cars sit a lot so I’m use to key in and priming pump once or twice. I will try as is
Another thought, again maybe I'm out to lunch but shouldn't the regulator stop flow through the return line when the system pressure is less than the preset?
next. When I cut the key off, it creates a void of fuel in the return, so if I get a check valve that lets fuel flow back into the tank but has a crack open pressure 1) it will too the siphoning if a line comes off of get damaged 2) will hold more fuel in the return line when its cut off so it will pressurize faster. Resulting in faster starts. I can video it and show you exactly what I mean how much longer it takes to crank
Afaik there should be no flow through the return if the system is below the pressure preset. The regulator should only allow flow into the return if it needs to reduce the system pressure.
I'm thinking your reg is not working properly or the system is not routed correctly.
Check out this page from Summit Racing https://help.summitracing.com/app/an...uymsuymq%3d%3d
My setup is as the drawing shows. It's a nasty fuel line and rail setup, -8 size, fed by a squash dual 450s on E85. It takes 4 or 5 primes and turning it over while fluttering the gas pedal to start if it has been too long, like a week. Overnight, it is just prime, then it'll start pretty quick. Within a few hours it starts like stock.
FPRs don't seal perfectly. They are made to open quickly and adjust to load. They do hold pressure for a while, but they all bleed down if there is a return. I think he is thinking that the check valve is a better sealing device and with a low cracking pressure of ~5psi or something, it could stop the siphoning back to the tank. I'll give it a try when I get a chance if no one else does.
mine is done just like that. I will be doing it for sure but I may get a different valve than the one I got from jegs. It’s kinda cheesy how it’s made.
it’s not immediate and if I forget to prime it, it’s embarrassing to have a nice car turning over and over an excessive amount of time to get it started. My preference, and I’m going to fix it. No matter what it takes.
Get picky on REAL issues...
check it.
ummm yea, it sounds normal. Because I primed it. I don’t want to have to prime it. I forget because for the past 27 years I’ve been driving, I never had to prime anything. The first start is how I normally start the car. You know, put the key in and turn it. It’s ok if you are ok with priming it. You might be used to that. I’m not, and I don’t like it and no one can convince me to like it. Ok. Ok. Lol.
