E85 fuel pumps what gives
OK here goes.. why not replace the stock 2004 gmc5.3 pump witha E85 pump to get more flow right..afterall E85 needs more flow for given HP!
stock fuel pump is MU1415 or equiv as verifed by dealer.. ok fine 28GPH..tested it too .spot on.
but I need something that will pump for 400-450 hp// so i figure get a E85 trunk pump that will fit.. NOPE
specs says MU-1553 IS for E85 vehicles..... nope that only pump 28 gph wtf>??
see below,,
spent hours on delphi website seraching for E85 pump that would support 400 HP.
NADA>.
soemthing doesn't make sense.. so if you run E85 I guess your truck detunes itself or limits RPM??
some pumps have same specs with higher current draws so somthing can't be right..
after you get to 2007 or so I find some E85 pumps htat flow 42 GPH so ..
so no I don't want to put in a walboro 255 that you cant find.,.. and my system is returnless.
and most aftermarket crap is just somebodys rebadged so....
any freking suggestiond to find a pump I can use>>> and fit in the stock can ior repalc ethe whole assmebly
i wnated to sitkc to delphi /ac delco becasue this is daily dirver that sees lots of miles
https://partcat.com/delphi
Bosch 66072
Bosch 67447
Bosch 67535
Bosch 69974
Carter P76232M
Carter P76241M
Carter P76511M
DENSO Auto Parts 953-3040
DENSO Auto Parts 953-5126
DENSO Auto Parts 953-5130
DENSO Auto Parts 9533040
Delphi FG0340
ReTech RE0881S
Spectra Premium SP3609M
ACDelco M10101ACDelco MU1156ACDelco MU1309ACDelco MU1314ACDelco MU1415ACDelco MU1417ACDelco TS1016AutoZone DFG0340CARQUEST M3480519E3609MGeneral Motors 19133449General Motors 19133450General Motors 19167467General Motors 19167468General Motors 19303385General Motors 19303391General Motors 19331937General Motors 19331960General Motors 25349027General Motors 25376408General Motors 25384360General Motors 25384361General Motors 88965371General Motors 88965386General Motors 88965391Magneti Marelli 1AMFP00033
Delphi Fuel Pump Module Assembly
FG0340
ep 0378
fg0157 delphi
when you look at the cross ref the specs are all over the place..
so............... look for a camero pump>?
remember my system is returnless
Thanks
