Looking for CHRS1313 dual pump experience
How does the kit fit?
What pumps?
If you used the vent/evap line, were there any issues with the stock connections?
What feed lines did you use?
What return lines did you use?
What regulator did you use?
What is your fuel rail pressure?
What pumps?
however i did install and run the lonnies doubles (sponsor on here)
flawless install, i believe he uses dual 340s tho, not certain. great customer service and extremely knowledgable.....i would recommend reaching out to him to answer your questions.
http://www.lonniesperformance.com
his site isn't the best and is a little tough to navigate but go look under fuel systems. his is cheaper than the chrs1313 as well i believe.
Aeromotive 5.0 external pump with a 12 AN sump to the factory tank and dual pumps in the bucket that can handle E85 should cover it.
This looks good:
https://ls1tech.com/forums/fueling-i...estions-2.html
