New intake, need advice on injectors
not size, but style, it’s on cathedral heads
Last edited by Lsx408invt; Jan 29, 2021 at 05:32 PM. Reason: Didn’t finish the message
I think the FAST intake needs tall injectors (LS1 height). You can call up Fuel Injector Connection and they can set you up with tall body injectors with more modern internals that are faster with more precise fuel control at low duty cycle.
Don't use injector spacers. Those things lift the nozzle out of the airstream and cause fuel to puddle on the injector bore.
What are you putting this in? What kind of connector is on your harness? That will be key unless you want to use adaptors.
traditional Ls1 height EV1 connectors will work if you have a f-body harness.
Don't use harness connector adapters either. Those things are total piles of ****. Buy an injector with the correct type of connector, or cut your connectors out and solder on new pigtails.
a good tuner can make almost any injector work properly. Have ran 80 pounders that acted just like stock.
buy a good brand name injector from the start, will save you lots of money and headaches in the long run. FIC has always done me good.
Talk to them about power goals with turbo and size accordingly.
I've got my injectors sized to operate around 65% duty cycle so that all the fuel gets in the cylinder for that intake valve event. My injectors can be reflowed to double where I am now if I want.
