help with whining fuel pump
Old Jun 17, 2021 | 08:29 AM
shanekennedy's Avatar
Default help with whining fuel pump
have a vortec 5300 in 68 camaro with walbro gss340 pump in a fuel sump pan with return-style pressure regulator set to 50psi
old pump sometimes made lower pitched humming sound
noticed the sound changed when i had the turn signals on. there was no fuel pump relay installed. doh!
installed relay & replaced pump assuming humming sound was due to lack of power & pump may now be damaged
now the new pump has a higher pitch whine, play attached file to hear
there is plenty of power to the pump now as both relay & battery are in the trunk above the fuel tank
what would cause this noise from the pump ? could the sound be due to a vibration in the sump ?
many thanks for any input offered
File Type: wav
Old Jun 20, 2021 | 10:37 AM
Project GatTagO's Avatar
Old Jul 26, 2021 | 12:05 PM
deatschwerks pump is nearly inaudible, thank you for the recommendation
