Recommend Injectors for E85
Old Jun 25, 2021 | 08:57 AM
Pwnage1337's Avatar
Default Recommend Injectors for E85
Hey guys
I want to switch my 370 to E85, since i can no longer get 93 octane around here and have heard some knock under power because of **** gas. I can only get 91 and don't want to go through the motions of mixing race gas in a street car.
Right now its a N/A 370" with PRC As Cast LS3 heads, 11.2:1 compression, Pat G Cam, 230/234, stock LS3 injectors in an 85 Corvette. I have an in-tank 255 pump. I think the pump should be large enough? My system is a return style at 58psi.
I think 80 Lbers should be enough...any preferred brand? Siemens Deka?
Old Jun 25, 2021 | 09:35 AM
01CamaroSSTx's Avatar
DEKA 80's is what I'm going with on the 99 Camaro and just make sure you have enough fuel pump.
In Pat G We Trust!
Old Jun 25, 2021 | 10:33 AM
Pwnage1337's Avatar
I think I'm gonna go to a 340. Apparently my pump might not live very long with e85 lol.
Is there a good vendor for the Siemens? Forum sponsored one?
Old Jun 25, 2021 | 10:55 AM
340 should be enough pump for 900hp and I purchased some through Tick Performance but they drop ship from Fuel Injector Connection. Bad part about E85 is uses three times the fuel so if a street car you'll be stopping often.
Old Jun 25, 2021 | 01:57 PM
Pwnage1337's Avatar
It is a street car, I just daily drive it locally. Pipe dream right now is to run a flex fuel sensor with a turbo setup so when I want to drive like a dipshit I can put corn in it and when I want to go for a trip I can put pump gas in it and have the tune adjust accordingly automatically.
Oh well lol can't risk destroying this engine so frequent fill ups it is
