Terminator X
Old Aug 26, 2021 | 07:59 PM
vht's Avatar
vht
Default Terminator X
I'm planning on going blow thru to start off with on my boosted 5.3 but if I decide later to go to injection would the Terminator X be a good choice for a street and strip car? Don't need nothing for the trans, their safety features are a good thing to have. The Dominator is over twice as much and then there is $600 or so for injectors. I'd like something that will support a 1000 at the wheels just in case I add more power later and there is the problem that I know nothing about this stuff. It'll be a complete new learning experience for me. Any advice appreciated.
Old Aug 27, 2021 | 01:14 AM
pdxmotorhead's Avatar
The only limitations of the Terminator I've noticed is,,,
1. O2 sensor 1 only.
2. Only a small number of inputs/outputs. adding 8 more is almost 300 bucks.
3. Documentation wonders a little bit and some of it based on file dates on the web page have not been updated in sync with each other. Forces you to do a lot of cross comparing on some of the detail setup and wiring ..
4. Speed density / MAP only no MAF.
These are not "bad" things, just things to plan around in your build.
ALL the NOS/2 step/brake stuff seems to be in there..
Old Aug 27, 2021 | 08:04 PM
vht's Avatar
vht
Thanks, I think it would have everything I need. I need to keep it as simple as possible because I know nothing about this stuff.
