5.3 on alcohol
Old Aug 27, 2021 | 10:38 AM
s11djack's Avatar
Default 5.3 on alcohol
5:3 on alcohol. Haven’t done anything yet but I’m interested in switching over. Can anyone give me some advice? I’m doing research as well. Would be carb
Old Aug 27, 2021 | 12:39 PM
wretched73's Avatar
You need to give information besides it would be a carb.
What are you working with and what are your goals??
Old Aug 27, 2021 | 12:46 PM
s11djack's Avatar
Right now iv got a 5.3. Holley intake, Holley 750 double pumper. Stock rotating assembly. 11:1 compression with head work. And a decent cam, 275/282, Lift .525/.525. Iv got it on 110 but I wanna explore methanol. Would like more hp, a I heard it’ll burn a lot cooler. Used in a derby car. So keeping heat down is always main goal. Just wanna know more about running methanol and what I would need in order to switch.
Old Aug 27, 2021 | 01:31 PM
01CamaroSSTx's Avatar
Good fuel system and get the compression up!
Old Aug 27, 2021 | 03:32 PM
wretched73's Avatar
The carb will need to be setup for meth
Fuel cell and lines will need to be compatible with meth
Old Aug 27, 2021 | 08:42 PM
Fishmasterdan's Avatar
I run methanol on a 408 for drag racing. Tips.
Make sure you have methanol fuel pump and it flows twice what you think you need.
You will need all methanol friendly fuel lines.
dont use anything aluminum unanodized.
Make sure your regulator can return enough fuel.
make sure your fuel filters can flow enough fuel.
if your using an 02 sensor make sure it can read low enough.
I flow about 800 lbs per hour efi if that helps you picking a fuel pump.
compression 15.1
it cools down going down track so it for sure keeps things cool. Didn't make anymore hp on the dyno but was worth 2 tenths at the track.
Old Aug 27, 2021 | 10:17 PM
LLLosingit's Avatar
When I raced dirt cars on methanol I had a portable fuel cell that I could easily hook up after the night was over to purge the fuel system with gasoline. Start the engine and let it run and listen for the engine to go rich and shut it down. It cut down on maintenance needed on the fuel system by a lot.
Since you're running a derby car I would make sure the safety crew knows you're running methanol, It burns nearly invisible and putting it out is handled differently than gasoline.
Old Aug 28, 2021 | 03:09 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
compression 15.1
If tuned optimally, you should have seen very noticeable dyno gains, as well as significant track gains. I find this odd.
Old Aug 28, 2021 | 06:54 AM
LLLosingit's Avatar
It would depend on the fuel he switched from and track conditions he typically runs on. I'm sure you'd see less gain in good cool air at sea level than you would in the heat at a higher elevation. Then you have to consider with EFI you don't get the intake charge cooling effect like you do with a carburetor and that is one of the reasons most people see decent gains. Two tenths is a decent gain even if it didn't show on the dyno.
Old Aug 28, 2021 | 07:29 AM
perfect explanation. When the air gets bad it's worth alot more et than sea level. The best part is for bracket racing I usually can leave the same number on it all day. May move .02 all day.
also dyno was a year between sessions.
Old Aug 28, 2021 | 11:56 AM
IGN-1A's Avatar
Default Compressed Fuel/Air Temperature
As stated above, the temperature of the compressed fuel and air in the cylinder will be lower when "meth" is the fuel.
The CR should be high, 14:1 + or higher.
Compressing the "mixture" adds energy as heat.
A way to add heat in the cylinder is to increase the Spark Energy measured in Joules and the Arc Duration.
Use a STRONG coil such the IGN-1A coil with a .045" SPG.
Also, a close Head Quench/Piston distance will help.
Old Mar 2, 2024 | 04:04 PM
slowpoke96z28's Avatar
How did it work out for you?
Old Mar 2, 2024 | 04:22 PM
To whom are directing your question? This thread is 3 years old.
Old Mar 5, 2024 | 12:36 AM
Most would understand probably the OP. A question like that is pretty timeless...why would i ask that question to anyone else on his thread without specifying them?
Old Mar 5, 2024 | 12:48 AM
But that would be a guess, or worse, an assumption.
Better to ask a specific question than have all posters here wonder whether you're asking them.
Old Mar 5, 2024 | 12:52 AM
The OP hasn't been here in over 2 years, which is why I said what I did.
I don't assume anything. The above is why.
Old Mar 18, 2024 | 09:11 AM
SUPERIORMOTORSPORTS's Avatar
I am about to do the same swap from E85 to Methanol. Bracket racing ls3 with plenty of fuel pump and injector. What afr's are you guys shooting for and what heat range plug. currently on E85 with a ngk 7 at 30 degrees and 12.4 afr on the gas scale.
Old Mar 18, 2024 | 12:29 PM
Full Power's Avatar
Originally Posted by s11djack
Right now ................... 11:1 compression .
but I wanna explore methanol........
.......Would like more hp,.
You'll want a LOT more compression., 13:1 is a good start for a Methanol engine. That was not a misprint. Methanol STARTS to make sense around 13 to 0ne.
You WILL get more horesepower.
You will need to DOUBLE fuel flow, plus a few percent, compared to gasoline.
Stoich is about 6 to 1 ..
. Methanol is happy from 6 to one Air/Fuel and can run rich down to 5.6 or so. .
Methanol is almost HALF Oxygen by Molecular weight, so you can pour HUGE amounts of it down your intake... As long as the engine is WARM.
Methanol has a much higher latent heat of vaporization.... means it runs like liquid *** in a cold engine.
Have fun, buy by the Drum.
Old Mar 18, 2024 | 01:26 PM
IGN-1A's Avatar
Default STOP Engine Wear with METH ONLY
Hi ALL, I ALWAYS MIX 5% RACE GAS when using Methanol Fuel.
