Diodes and Fuel Injectors
Old Sep 10, 2021 | 12:58 PM
LSswap's Avatar
Default Diodes and Fuel Injectors
Anybody using them?
Why?
Which ones?
How are you connecting them?.
What results?
Old Sep 10, 2021 | 01:00 PM
Originally Posted by LSswap
Anybody using them?
Why?
Which ones?
What results?
For we uneducated ones.... what is the purpose of them, and for what desired result?
Old Sep 12, 2021 | 07:19 PM
LSswap's Avatar
I hear some people believe they make the injectors close sooner which might allow really large injectors to idle better. I don't believe that 's the case, but trying to get other opinions.
Old Sep 12, 2021 | 08:25 PM
ddnspider's Avatar
People tune monster injectors without them and don't have issues. Seems like it's in hopes of masking a poor tune.
Old Sep 13, 2021 | 06:32 AM
TrendSetter's Avatar
ive never heard of people adding them but ive heard of them being utilized inside ECUs for this purpose. Someone mentioned that the new haltech has some updated circuitry compared to their prior elite ecus on some of the outputs that close things quicker with a diode.
i dont think its a big problem these days though, i had 1000ccs on my 2l evo that idled fine, and my 5.3 has a relatively small cam and does fine with 1500s.
Old Sep 13, 2021 | 06:36 AM
ddnspider's Avatar
They're typically used with inductors in parallel but reverse to provide a current path when the EM field breaks down and the polarity across the inductor flips. Never seen a reason for doing it on an injector though. Maybe a coil lol.
Old Sep 13, 2021 | 12:31 PM
IGN-1A's Avatar
Default Back ElectroMagnetic Forces
ALL MOTORS that operate by using the flow of electrons, current flow, that causes a Magnetic Field.
This "field" can be around the wire, the coil around the Iron and has N/S polarity.
This Field when it is reduced, during Voltage being stopped, will cause current flow in the opposite direction,
when that voltage is high enough to DAMAGE the gate in the semiconductor causing a short.
Motors ARE ignition coils, fuel injectors, VVT actuators, NOS valves and other types of motors.
The "grounding" of the BEMF will also speed up the motors operation.
The use of a 1N5366 is one choice for an injector, MOST coil drivers, IGBTs, have "built in" diode protection.
Old Sep 13, 2021 | 02:18 PM
Good to see Lance around again!
Old Sep 13, 2021 | 04:05 PM
pdxmotorhead's Avatar
Many of the standard little Bosch Relays in cars have a diode circuit in them across the trigger coil , to prevent noise ..
Old Sep 13, 2021 | 07:25 PM
IGN-1A's Avatar
Default Starter Shock, quite strong
Yes, I have been shocked by the operation of a starter motor solenoid.
MANY here complain about engine bad running/missfire, etc.
The EMI of an ALT Diode, a blown shorted diode, will cause EMI.
The A/C clutch, the cooling fan motor(s), fuel pump, etc. can cause electrical noise.
The cure could be as simple as installing a MOV or a TVS.
Most modern cars have a CAN buss that does not like noise.
Old Sep 13, 2021 | 07:37 PM
ddnspider's Avatar
Tvs is a poor choice given that it can't dissipate the heat if the duration of the transient is long in duration (i.e. milliseconds). MOVs aren't great either as they breakdown over time, are slow to react, and can fail shorted. A GDT would be worth considering though.
Old Sep 14, 2021 | 07:55 AM
LSswap's Avatar
Let's stay on topic. Let's keep it to Fuel Injectors.
So my buddy is having a hard time idling his 4 banger with 1500s. He's looking to get finer control of the injectors, with lower fuel delivery per pulse, at low pulse widths. He has heard that zener diodes can help him reduce the amount of fuel per pulse.
I don't think adding zener diodes to his existing setup will speed the closing of his injectors. My opinion is that the injector drive MOSFETS in his engine management, like most, have a built in diode to protect the mosfets and these diode slows down the closing of the injectors. Adding external diodes will only make it worse if the MOSFETS already have internal diodes. Any diodes shunting the voltage generated by the field in the injectors coil slows down that movement towards closing. But the diodes are necessary to protect the MOSFETS from high reverse voltages.
If you have a drive without internal protection diodes, then an external Zener that limits the reverse voltage to somewhere higher than 12 volts but low enough to protect the drive from high reverse voltage will probably speed the closing. But that would require a completely different drive method.
I also have an idea for another method to speed it up, but that requires an H bridge and is more complicated.
Lets keep the discussion to this topic.
Old Sep 14, 2021 | 08:33 AM
LSswap's Avatar
Here's how I see it. (note: I changed the diagram)
Old Sep 14, 2021 | 12:36 PM
ddnspider's Avatar
Flyback diodes would help shut off an injector sooner, not prolong it. The injector driver is switch power or ground for a period of time and shuts off "instantly", the problem is the field stored up in the inductor. Even though the driver is off, there's still a source of energy within the injector coil itself. You can add R in series with the flyback diode to dissipate the power quicker, but increases the voltage seen across the coil. It's all a tradeoff for turn off time vs. voltage amplitude. You could also put an R in parallel with the coil directly to allow a current path for the injector coil field after shut down, but it will always consume some current.
Old Sep 14, 2021 | 12:46 PM
LSswap's Avatar
Flyback diodes would help shut off an injector sooner, not prolong it. .
I disagree. I believe that if the driver FET or Transistor has a protection diode, and they probably all do, then no improvement with flyback diode. The internal protection diode already acts as flyback diode. Any load on the reverse voltage from the coil slows down the movement of the aramature.
Draw a diagram of how you think it should be connected and I will test it. I have an injector calibration test set. Drivers I use are IRF540n.
Old Sep 14, 2021 | 01:06 PM
ddnspider's Avatar
You are not taking into account the added impedance of the wiring harness and connections. A diode at the ECU will not work as well as one located at the coil. These are small signal/transient durations and parasitic impedances matter. I've worked on custom DCDC power supplies and saw volts/Amps off of expected due to cable line loss. I gave you other options in my last post and as said it's always a tradeoff. There's no silver bullet for instantly absorbing the energy of a collapsing field.
Old Sep 14, 2021 | 02:01 PM
what engine, ecm, injectors?
Old Sep 23, 2021 | 03:55 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
I have not thought about flyback diodes since I quit working on arcade video games. Sometimes I hate you people.
Old Sep 23, 2021 | 06:07 AM
ddnspider's Avatar
I promise they still exist and we have to use them all the time 🤣.
