Fuel return AFTER injectors
Fuel from the pump comes into one end of one fuel rail; passes through; there's a short junction that takes the fuel to the other fuel rail; the FPR is at the far end of that rail; and the return line hooks up to that. The pump moves a constant volume of fuel, and the pressure builds up according to the total restriction; the regulator allows fuel to return, such that the pressure remains constant. (or at least, the regulator's setting; which varies according to engine operating conditions. Pretty straightforward. Much in the same principle as the oil pump.
No diagram that I can offer, really. It's too simple to need that.
there is no “out” per say. Just one line in.
Holley makes a nice kit that can be set up with a double feed on the back and a y into a return on the front side. (You will need a regulator here)
the set up you have (if based on the vette filter/regulator) is good for 500HP with a decent pump. Can you explain about the FP loss?
mare you dropping during a wot pull?
or is it random?
If at WOT, what is the voltage at pump? Maybe a Boost A Pump?
