Where can I get vacuum?
I have a LS1 circa 2000. I am using a Tomei fuel regulator with it. It has a vacuum port and I am trying to locate a source to connect it to.
The rear of the inlet manifold has two vacuum ports - one for the brake booster and another for the air-con. I don't have air-con so I'm wondering if I can use this port to connect to the fuel regulator.
Does anyone know what the vacuum presure is coming from this port ?
The specs on the fuel regulator are at https://www.tomeiusa.com/_2003web-ca...regulator.html
Appreciate any advise.
Cheers,
Greg
Cheers,
Greg
