91 octane going to cut it?
Old Feb 3, 2022 | 08:52 PM
Tyler Dietzenbach's Avatar
Default 91 octane going to cut it?
799s milled down .030
Cam specs 222/233 115+3, .600/.575 Lift
36lb GTP Injectors
Racetronics R255LPH w/hot wire kit
98mm FTP lid
​​​​​SSRA
1 7/8 headers merged to 4"
25% powerbond pulley
As the title says, would 91 octane cut it right now?
after I install my TPIS 90mm intake and 90mm throttle body, 85mm maf, will it be enough?
93 is very hard to come by around here. The car currently sits with about 3/4 tank of 91 as the work is being performed.
Old Feb 4, 2022 | 07:59 AM
Cajun ELESS-ONE's Avatar
91 should be fine. The bump in compression will help prevent some knock. Just make sure the tuner pulls the correct timing and the fuel trims are good.
Old Feb 5, 2022 | 05:24 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Saying that a bump in compression will prevent knock is absolutely backwards, but given that the op is not at sea level, and has a cam big enough to bleed off some static compression, I see no reason this could not work.
Old Feb 5, 2022 | 07:33 AM
LLLosingit's Avatar
Not enough information, You would need to know what the compression ratio was before the heads were milled. Are the heads original to the engine? There is a big difference when you throw milled 799/243 heads on an engine that originally came with 317's versus a 4.8/5.3 that came with 799/243 heads from the factory.
Old Feb 5, 2022 | 08:27 PM
The engine is an LS1 with the stock heads and I'm going to the 799 heads, milled. Compression will be around 11.3:1
Old Feb 5, 2022 | 08:34 PM
pdxmotorhead's Avatar
Frop the OP's sig hes in IA,,
On average, Iowa is at an elevation level of 1,100 feet above sea level. At its highest peak, Iowa's Hawkeye Point boasts an impressive 1,670 feet above sea level.
Altitude isn't much of a factor in this question i'd guess..
Old Feb 6, 2022 | 07:31 PM
rpturbo's Avatar
Would you be able to run more timing with a different fuel, probably, will 91 work, yes.
I tune on a LS1, with 799 heads, and a LSA on it on 91. Granted, they haven't been milled, but even not milled it's at or near 11.0:1, and this has 9# of boost on it. Oh, and it iats tend to run a little hot on this particular car.
Old Feb 6, 2022 | 07:34 PM
Think it's worth adding Torco and tuning for 93 instead?
Old Feb 6, 2022 | 07:46 PM
Whats your operation plan for the car, daily+occasional track or track car that drives to the track?
Old Feb 6, 2022 | 07:50 PM
Mostly for fun, summer only car. May take it on trips but occasionally on the track as well. Guess I'd call it a weekend warrior with light track use.
Old Feb 6, 2022 | 09:03 PM
So just my opinion, we all pick the risk-cost factor we like...
If I'm driving on the street say 90% of the time,, I would tune for 91.
Additives are always a crap shoot if your not running a consistent main fuel source..
Same as mixing race as and pump, you wont know the result till the
expensive engine inside bits become outside bits..
Especially right now with supply chains heavily affecting chemical companies,
the additive packages are all over the place between loads of delivered fuel.
Only ones that are consistent are race gas out of a drum or Aviation fuel from a airport,
but your still in a bind with either from cost of the fuel or the cost of a additive to get the fuel
where it needs to be for your engine.
Not to mention the fed WILL hunt people down and fine them on using AV gas on the street. (Seen it up close...)
Your other option is do 2 ECU's 1 with a 91 street tune and 1 with a race gas/meth track tune
and always run a good gauge package so you know its playing nice.
At the end of the day I quit building street cars years ago, dual purpose is always a compromise in something..
If I want to race I run a race car.. since I don't street race.
Old Feb 6, 2022 | 09:10 PM
Very sound reasoning if you ask me. I use Top Tier brand gasoline from Kwik Star at 91 octane. Always imagined buying additives would be kind of a crap shoot. Quality of everything these days has suffered, so I agree with that comment as well.. sounds like 91 will be the ticket.
Old Feb 6, 2022 | 09:15 PM
Either way have fun with it..
Old Feb 6, 2022 | 10:41 PM
I can't wait to take it out in the spring... chomping at the bit
