deadhead Fast rails
Is this a terrible idea? Am I asking for headaches if I do this? Should I bleed the air from the backs of the rails before I fire it up?
Fuel flow would be:
pump >> regulator >> Y >> fronts of both rails >> plugs at the backs of the rails
...with the regulator's return line going back to the tank, and each rail feeding four injectors of course.
Thanks!
It ran fine. The engine was a rebuilt LS6 with a small cam. Not monster HP but again it ran fine.
I'm not too worried about starving the injectors since I've got way more fuel pump than I need (TI / walbro 450).
I mostly just wonder if air is going to hang out at of the far ends of the fuel rails and cause random trouble.
