Converting 4th Gen Fbody To 6an line
Old Dec 8, 2022 | 12:19 PM
Gotothelab1's Avatar
Default Converting 4th Gen Fbody To 6an line
I'm in the process of a 3800 (2001 Firebird) to LS1 (2000 Camaro) swap. The factory fuel lines were rusty and cut when I pulled the motor so I'd like to replace them with 6an line. Ideally, I would like to run the lines the whole way to the sending unit my original plan was to use the compression style fitting back at the tank but I just noticed the sending unit has plastic nipples and I don't know if that's such a great idea anymore. Long story short if anyone knows what kind and how many fittings as long with how much 6an line I'd need to make this work at the tank, for a fuel filter, and up at the rail I'd really appreciate it this is the last thing I need to figure out and order.
Old Dec 9, 2022 | 08:09 AM
LS1Formulation's Avatar
I purchased this for my '98 and it is absolutely a top notch kit. If you price out buying all of this stuff, you'll see what an incredible deal it is. Plus, you don't have to worry if it will work, it's got every single component that you will need ( link is for the 99-02 kit ). However, if you don't want to spend the coin for that, just purchasing a couple of push lock to AN adapter fittings should be perfectly fine. I would upsize the feed line to - 8 if I were you, though : http://www.ws6project.com/user_stor/...oducts_id=7631
