Factory EFI
Thinking factory EFI and using a Holley Terminator or ? $$$ is an issue since I don't want to drop $5K into it. Carbd right now as I had NO EFI parts with motor.
Thoughts on a Factory LS3 take-off ? (LY6)...or something better ?
What engine will you be using (cathedral heads or rec port?) and im assuming your referring to "factory EFI" as just the intake setup? Since you also mentioned a Holley ECM.
If you have rec port heads then the Ly6 intake is a great choice, you would be looking at around $2500-3000 to convert using Holley and a factory intake by the time you add in the rest of the fuel system.
I had all the carb and fuel supply, just needed an intake.
Now, every time I see a buddies car with EFI, just reach in the window, bump the key, starts right up...I keep looking, but don't want to give up any power.
I even looked at a Sniper system, but IDK. Thought factory may be a better option ?
Then adding a power adder (and E85) looks more feasible.
