Fueling question
Old Mar 16, 2023 | 01:33 PM
01CamaroSSTx's Avatar
Default Fueling question
After the fuel pump has ran for the 2-3 seconds to prime the system for start what controls the fuel pump to run while the engine is running? I'm guessing it's the crank position sensor that controls fueling but not sure and thought I'd ask.
Old Mar 18, 2023 | 11:39 PM
Bbknucks's Avatar
Yes ecm will not command fuel pump after prime until after it sees rpm
Old Mar 19, 2023 | 09:19 AM
Thanks, I was hoping that was the case and it wasn't dependent on the ecm seeing oil pressure since I'm switching over to mechanical gauges for oil, fuel and temperature.
