Factory Feed as return question?
Old Apr 11, 2023 | 11:28 AM
mblair's Avatar
Default Factory Feed as return question?
tried searching this with no avail... Using the Factory feed line as a return possibly, when doing this you block off the T/factory return with the Russell 648070(or like) and a cap, do you remove the stock filter? or does the flow just reverse through the filter? If flow just reverses I intend on changing the filter, just trying to verify so I can get this thing buttoned up. thanks!
Old Apr 17, 2023 | 09:00 AM
mblair's Avatar
Anyone? Main concern is if the filter media will invert and cling to the walls of the case and plug the filter... otherwise I can just put in another quick connect and take it out. Just curious what everyone else has done?
Old May 10, 2023 | 04:17 PM
30th t/a's Avatar
I just did this with my car. I did run it a couple times with the filter still in the line and didnt notice anything.
I then removed the filter and bought these parts along with a piece of 3/8" fuel line. Worked great. No leaks.
Old Jun 14, 2023 | 08:19 PM
zzracer's Avatar
You can leave the filter but put a new one in so you don't flush the used one out back into the tank.
