LQ4 Injector Question
Old Jul 13, 2023 | 01:09 PM
danyo492's Avatar
Default LQ4 Injector Question
Hey all, quick question here and I think I'm way overthinking it. Going to be running an LS6 intake manifold on my LQ4 build. Will be swapping heads and installing a Truck Norris Cam. I will be upgrading the injectors and fuel rail while I have everything torn down. Are the injectors in the link below the ones I want to run using the LS6 intake manifold? Or do I need to run LQ4 injectors with an adapter for the LS6 intake manifold? These will give me the correct 2.550" height to match the LS1/LS6 stock injectors.
https://www.fuelairspark.com/8-preci...injectors.html
Thanks in advance!
Old Jul 13, 2023 | 05:43 PM
68Formula's Avatar
Depends on what fuel rail you're running. If it's the factory LS1/6 rails, that's the correct length without needing adapters. If it's aftermarket fuel rails, depends on how whoever makes it designed it to fit. You'll need to ask the source.
Old Jul 13, 2023 | 09:03 PM
danyo492's Avatar
I was going to run the Holley Hi Flow rails for the LS1/LS6 so I think those will work with that.
