Fuel gage ohm readings for custom tank installs inside.
Coal Mining Director
If you are trying to find a custom tank fuel level sender unit to work with a factory gage, these readings came from my 1999 fbod gage:
33 ohm = empty tank = 0.57V
68 ohm = empty tank = 1.05V
100 ohm = 1/16 tank = 1.40V
150 ohm = 3/8 tank = 1.84V
220 ohm = 7/8 tank = 2.30V
270 ohm = Full tank = 2.56V
I'm sure there is some variance in factory gages, but this should be close.
If the sender is disconnected, the gage reads empty.
At the rear bulkhead connection above the axle on the drivers side is the fuelpump and fuel sender wires. the 12v source to the fuel pump is gray, the ground is black. The two smaller diameter wires are purple and gray with a black stripe are for the sending unit to the gage. The purple wire sends a 4.96 volt signal to the sender (variable resistor) and it drops the voltage depending on your fuel level.
Hope this helps someone trying to wire up an aftermarket tank.
7 Second Club
Originally Posted by slayer1234
Do you know the Ohms for a 94 sending unit i need to replace it but i have no idea where to look. or do u know where i might find a replacement?
Thanks for the info! I may make my own custom gauge, there are some sweet little PICs with ADC and enough outputs to drive a LED readout showing 0-99%
Originally Posted by xssive
I also noticed in HP Tuners, you can adjust the ohm / level readings in the pcm
Bringing this back from the dead to see if I can get and clarifications from some electrical gurus.
I had a stock 3rd gen gauge (0-90 Ohm) the stock resistors in the gauge were 22 Ohm (E), and 82 (F). So my reasoning was, match it up with something roughly similar for the 4th gen sending unit.
I rigged mine like this:
33 ohm = empty tank = 0.57V (I used a 47 Ohm)
270 ohm = Full tank = 2.56V ( I used 220 Ohm)
So essentially if the sender puts out anything less than 47 Ohm, it will read empty? That would be great for me, i'd rather trigger empty early than too late. And with my 220 Ohm for the high side, anything the sender gives above 220 Ohm will trigger full? Again no big deal, on full - it will just read full a bit longer than normal.
Old post I know, but just to add the extra info for those chasing it:
Adjusting the ohms values in HP Tuners only works if the OS you're using is from a vehicle that uses OBD2/serial data to control the gauges (i.e. 99-02 Firebird, Camaro etc)
It won't work if you're just trying to adjust it for an older style gauge cluster, as this takes the reading directly from the tank and is internally calibrated/set to fixed values.
I was trying to get the fuel to display on a custom android tablet dash only to find out the operating system in the PCM is not compatible.
The following users liked this post:
G Atsma (07-16-2023)
