Racetronix to Terminator X
I installed the dual Racetronix pumps with the new bulkhead connector and the intermediate harness into my 2000 camaro.
The intermediate plug plugs into the sensor looking thing on the top of the sending unit then into the new bulkhead and has a plug that goes into the wires from the front and you are left with the plug below
I am assuming red is power, blacks are ground then a signal for one pump and then another for the second.
how has everyone wired this all up going to the terminator?
can I forget about all stock wiring since the ecm is all out and just run the Holley?
thanks in advance..
Cody
thanks in advance..
Cody
Yeah I have that relay still in the engine fuse block but am not sure how to go from those wires to give the new pumps larger power cables.
This has been one of my biggest struggles and I more or less fabricated my own procharger bracket lol
So heres my dumb question..
Should I leave the stock plugs plugged in or remove them and cut apart the harness and wire as follows:
Terminator fuel line to stock pump relay
relay activation wire to second relay which activates pump 1
Terminator output to activate pump 2
Also what is the gray wire then? and dont I need to run power to the pumps?
Thank you!
Thank you!
The grey wire is the factory power wire for the pump that will power up for like 5 seconds for fuel pump prime it needs to see that RPM signal to keep the motor running
I have a Dominator ECU and after I repurposed all of my racetronix wiring to wire up my own relays for the pumps I realized I didn't need any of their stuff. The Dominator will do it all for me
Pin 30 can I run a fuse and to the battery?
Thank you so much for the help!
