LS Plastic Intake Vacuum Ports
Have the 25383922 intake manifold(seen it called both TBSS & truck). I want to run a vac line to an external aftermarket return regulator(at least I assume there should be one like on my TPI car).
Where or what adapter do i need to make this work? There is a plugged nipple on top of the intake but is there any cleaner side options? Other than a brake booster line Tee? The Cheap 92 TB it came with has a large capped port.
About to order from Jegs and Summit so would like to figure out if i need an adapter or w/e
The following users liked this post:
BOOT77 (07-25-2024)
This engine already has a larger size nipple/port there. I'll prob use a reducer off it at the least. Thought there may be at least a smaller pop-in option, to skip the adapter
