Ls1 running rich
goes like -25 sometimes. Can’t figure it out
Trims float on one bank or both?
Fuel pressure solid while idling AND driving?
I can somewhat see a situation where a "bad" wire was previously giving too low voltage to the pump, and your fix is now making more fuel causing rich, but that should trim out and stabilize at idle.
If AFR is floating around and pressure is solid/stable that makes me think an injector or O2 sensor is acting up but that'd likely show in one bank not both. O2 sensor also wouldn't affect WOT instability on a stock computer.
Is MAP stable and accurate? KOEO it should read atmosphere pressure.
