LS1 Noise from Injectors
Old Oct 2, 2024 | 04:54 PM
Dsah's Avatar
Default LS1 Noise from Injectors
I’m new to the Forum and am sure this has been addressed but I’m having trouble finding it. I just put Heads Cam and Lifters in my LS1
After driving for some time it developed a noise similar to lifters but not that metallic. Someone said it was my Injectors. The engine is out of a 2002 Firebird The heads and cam are from Trick Flow that included Harlan Sharp Roller Rockes. The injectors are Stock and came with the engine when I bought it ( it had ~ 40,000 miles) so I have not changed them. This noise also will go away for some time then come back I’m at a lost and with New Hearing Aids its Now Driving me Crazy
Old Oct 2, 2024 | 05:17 PM
Electronic fuel injectors do make a light clicking noise.
Some more than others, but it is normal
Old Oct 2, 2024 | 05:22 PM
Dsah's Avatar
This isn’t light and was not there before the head and cam swap I used LS7 lifters from Texas Speed
Old Oct 2, 2024 | 05:25 PM
Then are you sure it's the injectors making noise?
Did you measure for correct pushrods when you did the cam?
If your new cam has a smaller base circle, you do need longer pushrods.
Old Oct 2, 2024 | 06:06 PM
Dsah's Avatar
The Head and Cam Kit came from Trick Flow and came with push rods that matched the base circle
every thing was fine, Great Performance No noise. It was after ~ 500:miles this started plus it comes and goes. If it were a lifter or cam lobe going bad it wouldn’t go away. Performance hasn’t been affected, still runs Great Just sounds like S@#T
not Sure what it is. Wondering if anyone has had Very Loud injectors. When I first fire it off cold it sounds like it’s sucking a lot of air then settles down once warm. I have a long tube from Air filter to throttle body. ~ 2 feet to get cooler air. Sorry for grasping at straws but I’m stumped on where to look
Old Oct 2, 2024 | 06:18 PM
Dsah's Avatar
Also if I put my Stethoscope on each injector I do get one that sounds louder than the rest but not noticeable without
if I were to replace the injectors what’s the best to use. Also will I have to re tune ???
Old Oct 4, 2024 | 09:49 PM
wannafbody's Avatar
Scott Settlemeir claims a lot of the LS noise is from the injectors.
Old Oct 6, 2024 | 12:39 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
If the noise comes and goes you can 100% rule out injectors. You have something else going on.
