GEN 3 LS6 not getting fuel
After thinking about this all week I found something that it may be. I am running the Holley in tank fuel pump that I installed during my last build where I had a 383 Stroker and Holley Sniper I system. The Holley in tank fuel pump is a "returnless" system. The fuel rail I have on the car looks to be the stock fuel rail. Are there two types of fuel rails...a return style and a returnless fuel rail? AND if so, could that be the issue?
Here's an LS2 style fuel rail where I had installed a fuel pressure gauge on the fuel rail. The rail you have has the same and you can either move your fuel pressure regulator to be on the rail which I don't suggest you do but rather run a line from there to your FPR.
