Fuel pressure tester
Old Dec 19, 2024 | 02:43 PM
F14D's Avatar
Default Fuel pressure tester
Does anyone know where I can get a fuel pressure tester without that annoying clear tube that shoots out fuel and gives weird readings? I've found some online for diesels for around $40 but I'm not sure if the fittings will work. But they don't have those clear tubes. A link would help if anyone knows of one.
Old Dec 25, 2024 | 08:33 PM
91 Z28's Avatar
That clear tubing is just so you can bleed off the pressure after you have tested the system. Otherwise you'll go to remove and spray fuel all over. That being said you should be able to get them at almost every single parts store in the world
