Small patch for fuel return line?
Old Mar 15, 2025 | 05:33 PM
HolyBird's Avatar
Default Small patch for fuel return line?
Hey all, yesterday while doing some body work I unfortunately melted a small section of my return fuel line, the car had no gas in it so I wasn’t as careful as I should have been. It’s just past the quick release by the driver seat, at the beginning of where it starts to run parallel to the sill. Just wondering what my options are, do I have to replace the whole thing or can I just snip out the bad section and insert some sort of plastic/metal connector? Recommendations on where I can buy a replacement or patch kit? Also I’m sure I could find it online or by searching around but what is the diameter of the return line? Any help is much appreciated!
Old Mar 15, 2025 | 07:48 PM
Return is under next to no pressure. Being sensible, clamp in a piece of fuel line of the right diameter that fits snugly.
Old Mar 16, 2025 | 02:49 AM
HolyBird's Avatar
Sounds good, thanks for the reply!
Old Mar 16, 2025 | 06:53 AM
LS1Formulation's Avatar
Any parts store will carry a plastic fuel line repair kit. They're said to not be repairable, but I have done the same thing ( melted lines, only I had one hell of a fire when mine happened ) and I was able to splice together the lines.
Old Mar 16, 2025 | 10:35 AM
HolyBird's Avatar
I see, also glad to know I’m not the only one who managed to get heat that close to a fuel supply system, I guess I’m lucky it was drained cause it had bad gas! Thanks for the reply!
