Are these injectors enough for my build??
2002 Z06
Was on a stock Ls6 with a Novi 2000. I upgraded the fuel system to a single pump 350 and FIC #85 and I ended up blowing a piston.
New build is a fully forged LS2 403. I went with a Chris1313 dual 450 pumps. Full return system. I kept the FIC 85#s bc I literally just bought them. I was told they'll be enough.
I'm wondering if these will hold up. I'll be running a 3.25 pulley on the Novi expecting around 12-15 psi. I know I'm leaving out a lot but just trying to to get a general consensus if these injectors need to be replaced with something bigger.
On pump gas, you're going to be knock limited, not injector limited, so those 85's should be perfectly fine. My build is 10.5:1 and I never went over 12 PSI on 93. I'm running nothing but E85 now, didn't want to risk it.
