Fuel Pressure
Key On: No hold in pressure
Engine On: Around 60 psi
Engine with throttle in Park: Around 60 psi
I understand under actual load there might be a good drop in fuel pressure....
No wonder something felt a tiny bit off. I'm assuming the in-pump regulator is bad or something.
Would y'all replace fuel pump?
If so what's a good easy replacement on a 2002 Camaro Z28 with currently an intake, full exhaust, and a 3200 stalled FLT Level 3 for possible future upgrades (Cam) ?
40 mph cruising: approx 57 psi
WOT: approx 51 psi
Is there any issue with running with a possible bad regulator (assuming it's that) besides not holding pressure with the key in the ON position while engine off ?
Thoughts?
WS6Store has drop in pumps and if your basically stock then I'd go this route on a new fuel pump assembly.
Rick
