inline walbro pump question
Old Sep 5, 2004 | 06:52 PM
smeshey's Avatar
Default inline walbro pump question
does anyone have a pic of the inlet and outlet are they threaded so I could install AN fittings Thanks Scott
Old Sep 7, 2004 | 07:59 PM
1dirtyZ's Avatar
they are not threaded. more like a "slip on the hose and clamp it" deal.
Old Sep 7, 2004 | 11:24 PM
LS1Sandrail's Avatar
My Walbro inline pump came with female metric threads. I bought an adapter from Earl's or Russell to get to -6 AN to plumb the rest of the system.
Old Sep 7, 2004 | 11:26 PM
smeshey's Avatar
Default now i a confused
ok does it come with slip on to hose clamp that can be screwed out or are there more than one type of inline pump? Thanks Scott
Old Sep 8, 2004 | 02:07 AM
1dirtyZ's Avatar
thats odd, the one i have ( the 255 lph version) has the slip on type connector which you can't remove. are there different versions of the pump??
Old Sep 11, 2004 | 05:51 AM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
All Walbro HP in-line pumps have metric female threads.
Walbro makes / Racetronix carries -6 and -8 AN male fittings.
The standard install kit comes with 5/16" hose barb fittings and copper sealing washers. The copper sealing washers MUST be used with all fittings installed on the Walbro in-line pumps.
If your in-line pump has a fixed barb inlet and outlet then chances are it is a Airtex T-Rex 200L/Hr pump not a Walbro GSL392!
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old Sep 11, 2004 | 09:10 AM
smeshey's Avatar
Default pump
well there we go Thanks Racetronix
Old Sep 11, 2004 | 11:34 AM
1dirtyZ's Avatar
thanks for clearing that up!
