Fuel system needed for 700rwhp?
Old Sep 14, 2004 | 08:47 PM
BOOSTAT4500's Avatar
So it sounds like a dual intake setup with bigger lines and a new rail with a return should about cover it, correct? Since I allready have an in-line 255L could I get away with that being like the second in-tank pump and just do 1 pump in-tank? Or should I just run all 3 pumps? Or ditch the in-line? Thanks for all the responses!!
Old Sep 14, 2004 | 09:09 PM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Ditch the in-line pump.
A Racetronix in-tank DP system will support 700RWHP w/ using the factory feed line along with a FM FPR and -6 return line.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old Sep 15, 2004 | 06:15 PM
SSNXTC's Avatar
are yall going to make a dual kit for the plastic tank guys? thats what kind I need
Old Sep 15, 2004 | 06:19 PM
Racetronix's Avatar
LS1TECH Sponsor
We have for years but it is not a D-I-Y kit.
You have to send us a module to fit the hardware onto.
Most people who think they need DP's do not.
Most people are able to use a single Racetronix system with or without a booster.
__________________
>WEB SITE<
Old Sep 16, 2004 | 05:32 AM
BTL FED's Avatar
Dual intanks sound like a good idea.
Or you could run aftermarket stuff for the rails, fuel line, regulator and tank.
I currently run a Speed Inc. gas tank and some aftermarket rails. I run one external Weldon 2025 pump right now. I am probably going to dual Bosch pumps from Speed Inc. very soon. Those would again be dual external pumps.
Why are you going to get rid of the weldon, I dont think you can get better pumps than weldon IMHO????
